hi
i have sony kd-55xf9005
i watch movies throw usb socket on the side
the movies are .mkv with seperate .srt file
its working great....
but today the tv was updating
and after that,the texting was different
the text size is bigger,higher up, then a black frame around it
IT was not that before the update
how do i change it?..i cant find in settings
mail me: roger_sundsvall@comhem.se
SOLVED
the app called video.for usb stick......no settings there for subtitle
BUT...the APP......google play Movies...then .settings
there are the subtitle settings....
can change..size,,color.high....etc etc etc
