Hiii guys/girls maybe
I have a problem with the TV, (ddddd) :D, it restarts or gives me an a error (2123) while trying to install update.
The has a build 2.287, android 5.0.2. "SVP4KDTV15_EU-user 5.0.2 LGY75.S143 2.287 release key"
If i try the newest os avaiable (v5.457) with USB update, it restart on 56% every time.
If i try with automatic update, connected with UTP it restarts on 52%
If i try with automatic update, connected with WIFI it restarts on 52%
I made a factory reset, going to settings - storage and reset - factory reset. The TV resets and i get a wizard to set up my TV.
Because i have a android 5.0.2 the buttons reset (volume - and power button) while turned off and then while holding the buttons i put in in the power outlet, then wait till powers on the LOGO. It just turns on and loads android. It does not reset the TV.
I have tried 3 different version of firmware: v3.925 and 5.381 and 5.457 all for "KD-55X8509C" with a USB method.
Formated FAT32 and NTFS, tried USB 1, USB 2, USB 3.
I even tried putting 2 firmwares (same version) one with original name one with upgrade_uploader.pkg With no luck.
TV is not usable becasuse of the androdi 5.0.2 i need atleast 7.0 beacuse of the software i would like to install.
Only the newest version comes to 56% the others restart on 52% with usb or ethernet.
What else can I do, has anybody had a similar problem?
Regards and thanks for the answers
This TV wouldn't support Android 7 version, also did you use this file: https://www.sony.co.uk/electronics/support/software/00259461
Hi
I tried this one: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x85xxc-series/kd-55x8509c/software/002594...
Regards
Hi
Sorry for late reply, I have tried the link you send and the TV said it cannot upgrade with this USB key ....
I just bought mibox tv. And its ok
