Salutare tuturor!
intampin o mica problema la tv meu Sony Brava model KD-49XE7077,
cand dau pe telecomanda la lista de programe adică informații imi apare pe ecran Acces indisponibil la informații.Țin sa Menționez ca softul este actualizat.
Oare de ce întâmpin aceasta problema?
Multumesc frumos
This forum is for English speakers, can you re-write the question in English?
Model -KD-49XE7077
Hi all!
I encounter a little problem on my TV Sony Brava model KD-49XE7077,
when I turn on the remote control to the list of programs, ie information appears on my screen. Access unavailable to information. I want to mention that the software is up to date.
Why am I having this problem?
Thank you very much
