Hi all,
I am writing this post just to see if sony can upgrade the very laggy and slow tv system and android.It is worst than a cheap chinese android hdmi stick. Issues:-
- Very slow system, i guessing for very low spec processor and ram + very lagging system
- Sometimes When i browse with opera i get reboot of the system
- Opera very difficult to close any advert...
- Quality of standard digital tv is very poor the scaling is very bad but hd and 4k is ok
- Opera browser is very slow and difficult to manage with the built in remote control.
- Remote control very slowy
- Android tv google play does not have any programs....
- With some programs I lost the mouse and i can not drive the program, I lost the focus
- Hd recording does not work
This just with 3 days
If the browser is your main concern I may suggest you to install Chrome: it works exactly as on a tablet. To installa it you have to sideload it (go to play.google.com from a PC and choose to install aon your tv). You have yo use a mouse to use it and you can do it also using the TVsideview app (if you don't have a real mouse).
To run app sideload it's best to have a different launcher (you'll not see them in your home menu) like sideloadlauncher.
