x
profile.country.GB.title
Donny1
Explorer
Sony Bravia XR-55A84L
Hi Guys,
I've just ordered above TV and it should be delivered in a few days. I've  FreeSat and FreeView boxes which I used on my old Sony Bravia TV.
My question is do I have to use both boxes or would I be able to connect FreeSat and FreeView connections directly to new TV ?
Thank you in advance.
2 ACCEPTED SOLUTIONS
Accepted Solutions
daveyh64
Enthusiast
Your TV has connections fort both Satellite and Terrestrial TV.
So you can use both boxes with your TV and use the input button on the remote to switch between the two.
Or you could choose only one box to provide you with TV and not connect the other, up to you.
Donny1
Explorer
2 REPLIES 2
daveyh64
Enthusiast
Donny1
Explorer
Thank you.
