Sony bravia KD65AG8 picture problems
SOLVED
profile.country.GB.title
RusCook
Member
Anyone having picture problems that are like concentric circles on screen from a light image on a black background. Sony have told my that my TV is working within specs so they won't do anything & the TV is just ove a year old.
1 ACCEPTED SOLUTION
Accepted Solutions
RusCook
Member
Ok thanks for the help, I've changed the settings and will let you know if it works, cheers 👍
2 REPLIES 2
profile.country.IT.title
rooobb
Expert
It is called colour banding and it is due to the low quality of the source not the tv. You may want to enable the smooth gradation filter on the tv to try to enhance it but it still depend on how bad is the source.
RusCook
Member
