why is there a lan cable when this tv has built in wifi please
@mandy30 wrote:why is there a lan cable when this tv has built in wifi please
Hi @mandy30
According the the specifications “what’s in the box” there is no lan cable supplied. However it doesn’t matter as you can use WiFi or Ethernet, your choice.
thank you so much for your help
