Hi
I am going to try set up my new tv myself tomorrow,have,nt a clue how to do it and the booklet is,nt much help,I want to connect my sky q box,which hdmi port do i choose and also what is the ir blaster please
@mandy30 wrote:Hi
Hi @mandy30
Sounds like perhaps you should have paid the extra for them to set it up for you
Unless you have a HDCP 2.2 compliant soundbar or amp then you should connect you Sky Q into HDMI 2 and set the HDMI signal format to Enhanced. Home -> Settings-> External inputs-> HDMI signal format-> Enhanced format.
You can safely ignore the IR Blaster as it doesn’t work with Sky Q (only Sky+).
thanks for the reply,I dont have a soundbar so will just use hdmi 2 then,The set up cost was going to be quite expensive thats why i did,nt bother
