I am experiencing digital channel pixelation on several channels on above tv.
I have been running two TVs from one digital aerial without any problems as the aerial transmitter is close to my address. When the pixelation occurs, I have checked the Panasonic TV in my other room and the pictures are all perfect so this eliminates any aerial problem.
Can anyone make any suggestion please.
To eradicate my pixelating issue with the above tv, I reset the tv back to factory settings and all is well so far.
