I have just bought a second hand Sony Bravia 55 Inch W80C. However it was previously mounted on the wall, I'm looking to use the TV stand instead. I have the metal TV stand, but not the brackets that it screws into. Does anyone know where I can order these online?
Thanks
Hi there
Is this what your looking for:
http://www.4sony.co.uk/stand-neck/product.pl?pid=5071003&query=Kdl-55W805c
Hi there
Yes! Thank you, do they come in pairs or just single units?
Thats a good question - i dont know. You might want to confirm with them first.
Contact:
http://www.4sony.co.uk/general-enquiry/customer-services.pl
Thanks for your help!
Your Welcome
