Hello everyone,
Could you somebody help me with automatically TV turns on?
I bought Sony 55 inch / A8H model last month.
TV is impressive, but this worries make a little.
Thanks and best regards,
Hi Peter,
Can you please check if "Control remotely" is enabled in the settings menu?
https://helpguide.sony.net/tv/haep1/v1/en/06-03_01.html
If so, please disable and check if the TV is still starting by itself.
Hi Peter,
Hello Peter,
Thanks to your reply.
I disabled option to automatically turn on TV via mobile phone and now it is ok.
So, I hope that was the correct solution.
Thanks Petr
