x
Sony 65XD8599 light bleed
mixterz
Explorer
hi,
seens to be a recuring issue and im not impressed .
TV is less than a week old and on first test of a film in low light i noticed cloudy patches on the upper left and right hand side also two strands of light beeming up from the lower left hand side which is irritating to the point i dont use the TV now.
i have the tv insured by knowhow through P.C World. so do i go through them or Sony by warranty ?
2 REPLIES 2
Anonymous
Not applicable
Hi there
If its warranty issue - you go through the retailer you purchased it from.  As its less than a week old, I would request an exchange. :slight_smile:
profile.country.GB.title
SnAkEs1210
Member
Hello
I seem to have a similar problem but it's not during dark scenes, it's when a solid colour is displayed, mainly red, green or yellow. For me I have a light patch in the top left hand corner but it's not there when displaying black. Here are some picturesTop left is pink instead of solid redTop left is pink instead of solid red
Almost looks like sunlight hitting the screen but this is actually some sort of light bleed
