- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello, I currently own a 55XF9005 (android 9) and since last spring youtube recommendations do not appear in the home screen. Only solution I found so far is to uninstall youtube updates back to the factory version.
I waited long for some kind of fix by Sony, but nothing yet. Has anyone had similar experience?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @tsstss
Then I believe this related to the app updates itself, you can uninstall updates for the app and use it that way if you don't want the new update features.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for your reply, I did everything you proposed - tv was updated btw. If I update the youtube app to the latest version the recommended/trends etc lines disappear unless I go back to the original factory set version.
Having a look on internet I found many others complaining on this matter.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @tsstss
