Hi Sony, I have updated the software on my Sony TV and now it will not switch on? I can get it to come on by switching off at the mains and back on but it will not turn on by the remote. I am also finding it difficult now to connect to Wifi as it keeps dropping out. I notice many others are having the same issue since the update. What is the fix? My tv is a KD75XF90xx
Sorted my issues out yesterday after update .are you with sky by any chance..do you keep losing WiFi connection ..
My soultion was to make sure your time is set to network time on the TV not local time ..I've read that works for some but didn't work for me.,so I did some more digging and tried logging into my router and disabled ipv6 ..and now for the first day sinse last Friday I have had no issues ..before I did that I was losing connection every 20 to 30ins some days after an hour
