Has anyone got Viaplay to work on Sony Android TV using Sideload Launcher?
I can install the Viaplay app but it turns the picture upside down, and when I hit "Log on" it just loads forever without ever getting to the login page.
Hi there
Im not in Sweden to test, but there are many apps that sideloading fails.
In regards to the picture upside down, try sideloading an app called 'set orientation'
https://play.google.com/store/apps/details?id=com.googlecode.eyesfree.setorientation&hl=en_GB
