x
Feroluce
Explorer
Cyan led flash
I have one of the Android tvs
Every 30 to 40 minutes the led (and bottom of the screen) flashes cyan twice, five seconds apart.
The manual says this indicates wifi connection but wifi (and Bluetooth) is disabled.
I've tried denying permissions for everything to share anything (I've even disagreed to the basic sony agreement at setup), but it still happens.
Does this flashing mean something else or is it another bug?
1 REPLY 1
Anonymous
Not applicable
Hi there
You might need to individually turn off wifi from each wifi device you have in your household and hopefully you can determine which one is 'pinging' the tv.
However, if your in a flat like me - the person below me kept trying to connect to my TV via bluetooth, until i eventually disabled it.  Im sure they had no idea what they were doing!
