I installed this tv a year ago and was quite happy with it - great picture! It took a lot of learning to move around the menus as the tv does a lot more than my 10+ year old Panasonic tv did. I chose not to install Google or use the Google remote control. However when I tried recently to access the bfi streaming service in the UK I found that the tv does not recognise this service although it does support Netflix etc. It does not have a good internet browser and it was very time consuming to connect and use the bfi service. So I am considering a move to install Google and use the Google remote control on the tv IF this would make access to the bfi service easier AND if I were to lose nothing by making the change over. Should I make this change? How do I make this change?
It sort-of sounds as if you are trying to use this over a web browser?
You should go to the Play Store on the TV, where you should find the BFI Player app, which should appear because it is supports Android TVs, and your TV is an Android one.
Unless, that is, you have already done this, and it is the app that you are having issues with?
Thanks for getting back to me. What you say is encouraging.
However when I installed the tv many months ago I chose the Sony interface and not the Google interface. I cannot find Google Play Store, and I am uncertain how to install the Google interface now.
Here’s some Sony Help on the topic:-
https://www.sony.co.uk/electronics/support/articles/00226737
It certainly looks from that that you can get to the Play Store from Android TV, and you don’t have to go over to the Google side.
I don’t have a TV enough like yours to try it on, but give it a go, see where you get to.
I've sorted it, I think!
Thanks, royabrown2. Previously I'd used the Sony remote and found Play Store, tried to download the bfiplayer app, and then nothing happened.
I put batteries in the other supplied Sony Voice remote for the first time, and did Settings/All Settings/System/Remote control etc and got the Voice remote recognised (replacing the previous one). Then I went back to System and chose and stepped through New Installation. This gave me what I called a Google tv interface. From Play Store I had a much larger choice of apps from which I chose, installed, and then opened bfiplayer. I don't think I've lost anything except time and a number of buttons from the previous remote, some of whose funtions I think can be performed in other ways.
Why did Sony deliver two interfaces and two remote controls? One seems enough. Sony caused me confusion.
@Lord_John Check this link out, it explains the difference between the two remotes and the importance of each one: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-43x75wl/articl...
Yes, that article is relevant to my situation, although it does not mention that I need to use the RF / Google remote to access many more streaming apps than the other remote. I do not recall the article arriving in my tv packaging. It also requires me to look up my tv model to see if it applies. MORE SPECIFIC AND TIMELY GUIDANCE WOULD HAVE BEEN INVALUABLE TO ME. The tv arrived without a model specific user manual, either on paper or online, so it was difficult for me to find the solution to my problem.
@Lord_John For any future issues, they have an online help guide for that TV that you can search on it using keywords: https://helpguide.sony.net/tv/kaep1/v1/en/index.html
Installing Google and using the Google Remote can make it easier to access streaming services like the BFI, as Google TV has better app support and a more user-friendly interface. To make the change, you'll need to enable Google Assistant and link your Google account in your TV's settings. As for losing anything, you shouldn't lose any major features, but be aware that the Google Remote will replace the One Remote for certain functions. If you want a more streamlined experience, it might be worth a try!
