Hi All,
I just received my new Sony Bravia OLED TV. Model number KF55AG9.
I have set up my gaming consoles on there more specifically my PS4 Pro. I use this to watch all my blu-ray movies on as well as play games, so understandably I have selected game as my picture option.
However I did notice when watching Star Trek: TNG on blu-ray that at the bottom of the screen there is screen tearing. Like the bottom of the screen could not keep up with the rest. Once I changed picture mode to custom and adjusted setting, it was fine. I don't really want to have to keep changing picture mode if I don't have to and wondered if anyone knew of a work around?
Thank you.
Hi there,
I'm looking into this and will update the thread when I have an answer.
Best wishes,
Sean
Have you tried enabling Auto-picture mode in the settings? I think it should deliver on exactly what you want.
Unfortunately that did not work.
As you can see, it only affects the bottom of the panel. When switching from Game mode to cinema or custom it's fine. I'm sure it isnt the panel that is the issue but it is being replaced anyway as a dead pixel was discovered a day after getting the TV :(.
Thats a settings issue.
You need to recheck the ps4 settings for blu-ray, and disable it's "automatic" settings.
And as for game mode, it's a blu-ray, not a game, so no game mode.
You need to match up the displays output with the ps4's, be it 60hz, or 24hz for movies.
Hi mrmercury,
Does this happen on all external devices connected?
Cheers,
Rose
Hi Mrmercury,
Let me know how it went.
Cheers,
Rose
