Hello,
I’ve got the above TV and recently a line has appeared going all the way across the screen, at first I thought it was a line of dead pixels and had given up hope that it could be repaired, so I swapped it with my gaming TV.
Now I’ve noticed that it appears to be a line (about 1/4 inch thick) that is about 2 inches too high and in the wrong place, by that I mean the line that I thought was dead pixels is actually trying to display a line of image that fits in about 2 inches lower. This is shining a bit of light that it might be something mechanical and could be repaired.
Any ideas or tests that I can carry out to sort the problem out? Happy to try replacing components if there is a chance it would potentially fix the problem.
Unfortunately your 2017 tv seems broken...
I do not know what do you expect from a user contributing in a community even if tagged as expert, if your tv is broken (and from the description you gave it seems the panel at fault) is like it is. Or you want me to go through all the checklist the support goes through (restart the system, reset to factory, disconnect any device, etc...)?
And also the other comment do not need really a reply but if you like ... no it should not break after two or three years the expected life should be more, but it happens and that is the reason for warranty (in uk you have only 1 year in Italy is 2 years) and extended warranty sold along with the tv. If you did it you are safe, you'll get a brand new tv for free. Cheers
Surely is the wrong place, for hardware problem you should contact a Sony Support center. None here is able or permitted to give you advice on how to identify a board broken and how to repair it.
Why do you worry about my profile? I wrote something wrong? Do you thing I'm getting payed in order to help others? Or do you expect a kind of magician who can solve any problem?
Hi @adarsco I think you have successfully burnt your bridges here 😀 I would try Sony UK Support .
