Hello, don't be tired. I use Sony KD-55X85J TV. There is no option of screen mirroring and only once I don't know what program I installed that caused a software shock, and the screen mirroring was brought to the disabled programs section, which did not have an activation option at all, and after I did the factory settings, it went away. I wanted to ask if there is a way to enable the page reflection option?
It's just that I completely updated the TV and Android apps, but still there is no option to mirror the screen
Hi @Alirasouli
Unless I have missed it, you haven't told us which device you are trying to mirror from?
For Android and IOS devices you don't need anything special.
For Android - use Google Home on your device.
For IOS - it uses Airplay2, select screen mirroring.
