Hi, i just bought a KD-65X85J sony tv and im trying to get bravia core to work but it keeps asking for a voucher. How can i get one ? Thanks for any help
Hi @avenger
That's because you don't have a Bravia Core TV. Bravia Core TVs begin with XR and yours begins with KD.
Have you signed up for Bravia Core, if so you should have been asked to include your e-mail address
or telephone number. The voucher code is sent to whichever you picked, check.
Enter the code sent to you on the TV.
https://www.sony.co.uk/electronics/tv-support-bravia-core
Hi @avenger
Ok thanks for the help
i have
sony bravia A90J OLED 83 inch
i want create account
but i don’t have
bravia core voucher code
please help me
I believe you will need to contact Bravia core support, if I remember correctly, they have an email address you can use.
Hi i have a sony 42 90k tv my bravia core has stopped working how do i retrieve my voucher my sony is only 7 months old thanks
You cant get one if it didnt come with the tv. Only sony tvs with xr after them get the vouchter
Hey @StevieV, try reaching out to BRAVIA core support directly. their email is support-GB@sonypicturescore.com
I did. The voucher is only for the xr model
