Since the last couple of updates my screen mirroring with samsung s5 has died, if i restore the TV back to factory defualts it works for around a day then just says failed when trying to connect.
Any suggestions i use this feature allot
TV is KDL 55w755c
Hi there
Its always Samsung mobiles that have issues
Anyway, when it doesnt work, have you noticed if the Wifi is working on the TV? Does other network apps work ok, like say YouTube?
HI
Yeah everything else is perfect, youtube, casting, sideview & remote etc...
just strange how it works straight after a factory reset for a while then dies, have a windows phone here at work will give that a go
Let me know how it goes with the windows phone.
Just the same 😞
had the tv a good 6 months, only issues over the last month or so with screen mirror
theres a ton of issues with this TV worst being the random crash's & remote deciding to stop working half way through something (however sideview remote seems to work when this happens). Screen mirrioring was by far my favourite feature
no one else having issues with this ?
very frustrating
@Prior20 have you tried unregistering your device from the domestic network on the tv and redoing the procedure anew? sometimes it solves...
just tried what you suggested and still no luck 😞
Hi there
Ive escalated your issue to Sony Support, so they should be in contact with you in the next day or two (not weekends). Ive been using screen mirroring on my Z4 Tablet to a KDL-55XD8577 with no issues.
Im not sure what else to suggest, so hopefully Sony can figure it out.
