Hi my TV restart it self after a few minutes when im on the internet or Netflix or settings. Have tried to reset the TVs settings but it doesn't seem to work. Is there anyway to reset the TV manullly like a rest button?
Hi Frahm74,
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime though.
Thanks,
Pascale
Hi Frahm74,
I've searched the Sony website. I found this article which addresses the continuous reboot loop you explained: http://bit.ly/2Xna889. I'd recommend following the steps in it.
Cheers,
The_Black_Rose
Hi Frahm74 ,
I believe your TV needs to be repaired. I will try passing this to Sony.
Cheers,
The_Black_Rose
Hi Frahm74,
I believe they'll be in touch with you soon.
Cheers,
The_Black_Rose
