Restarts KDL-50W808C
profile.country.SE.title
Frahm74
Explorer
Hi my TV restart it self after a few minutes when im on the internet or Netflix or settings. Have tried to reset the TVs settings but it doesn't seem to work.  Is there anyway to reset the TV manullly like a rest button?
9 REPLIES 9
profile.country.GB.title
Pascale_F
Moderator
Hi Frahm74,
Try following these instructions.
Thanks,
Pascale
Frahm74
Explorer
Hi. This did not help. Now the TV want start at all. The android logo did show and then it started again. Now I only have a black background and the led lamp is blinking slow
mvh Marcus Frahm
Pascale_F
Moderator
Hi Frahm74,
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime though.
Thanks,
Pascale
Frahm74
Explorer
Thanks white led lights is blinkings now and then screen is black
mvh Marcus Frahm
The_Black_Rose
Specialist
Hi Frahm74,
I've searched the Sony website. I found this article which addresses the continuous reboot loop you explained: http://bit.ly/2Xna889. I'd recommend following the steps in it.
Cheers,
The_Black_Rose
Frahm74
Explorer
Hi. Sorry this don't help. The TV want start at all now. The android logo pops up and than
mvh Marcus Frahm
The_Black_Rose
Specialist
Hi Frahm74 ,
I believe your TV needs to be repaired. I will try passing this to Sony.
Cheers,
The_Black_Rose
Frahm74
Explorer
Ok. Thanks
mvh Marcus Frahm
The_Black_Rose
Specialist
Hi Frahm74,
I believe they'll be in touch with you soon.
Cheers,
The_Black_Rose
