So after 6.0429 update I noticed a wierd bug when I turn off remote start from network settings (by default is ON controlled by apps).
What happens is with that off every time i turn on my TV there is a big delay with remote I have to push the button few times to make it work and this lasts for about maybe one minute and then is back to normal.
When I leave remote start ON everything is fine and remote respond immediately without problems the second I turn on my TV...
Anyone else having the same?
Have you tried clearing the cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data) then restart the TV by holding the power button?
