After updating to the latest firmware available (v6.5016), after turning the TV off, and letting it turned off for a few hours, it refuses to turn on. When I press remote power button, the Sony led become white for on sec and then it turns back off. The workaround is to keep pressed on power button from remote, wait few seconds and then press short again on that power button.
It starts.
Does someone have this issue?
Is it possible to downgrade to an earlier firmware?
Best regard,
Hi @sandula001
Try going to Home - Settings - Network - Home network settings - IP control - Off. Some users reported this as a fix for the issue.
Hi @Win_88 ,
Thanks mate for the answer.
The IP Control was already off.
It is strange because this issue is random.
After deep sleep, sometimes it's working fine, sometimes I have this issue. I did not find any connections.
I will probably have to wait for the next update.
That seems to be the only thing left to do sadly.
