Have problems recording on my 55xd9305 tv its connected to a WD MyBook HDD it is registered ok and records fine to begin with then the next day it is unregistered, have to pull the cable out the back of the MyBook then plug it back in then it is registered again. If i have programmes on a timer when it is unregistered they don't record and i get a recording error, it is annoying as i have to remember to check the MyBook before any timer recordings start does anybody know of a fix for this please?
That indeed got broken with Sony's Marshmallow based firmware The problem is now over a half year old and Sony does not feel the necessity to fix such key features.
You can find several USB issues inside my Sony bug tracker.
Also my review might be worth reading.
Can confirm with the latest update my hard drive can record now even with the tv having been in standby mode glad this problem has been fixed just waiting for the latest Android firmware and i will be happy
Thanks for the reply guess i will have to put up with it at the moment hopefully it will be addressed in the q4 update
