- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a KD-43XD8099 and now have three isues since an update, 1, how do i stop the samba box from coming up when i swich on, 2, my set now defaults to channel 42 when turning on, regardless of the station being used when turned off, also if changing outlets, for example, from recorder to TV, the TV will open on Ch 42, most frustrating! 3, when using the "jump" button on the remote it states " function not avaible" ! Can anyone offer some advice please, many thanks.
Roger.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Q1 - Samba TV
Please see point 5 in the Android FAQs: HERE (although best wait until fixing Q2)
Q2 - Default TV Channel
I am unsure why its defaulting to channel 42. I cannot see any settings to modify this. As this has only happened since updating the firmware, I would suggest a factory reset of the TV. Instructions : HERE
Q3 - Jump Button
Most likely resolved with factory reset as in Q2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Q1 - Samba TV
Q3 - Jump Button
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello, Many thanks for your advice regarding the three issues, pleased to say after following routines as per your suggestion all has been resolved, thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, Sorry but the same problem has now surfaced again, the tele is defaulting again, now to chn 124, and the jump button on the remote no longer works, so all as pre factory re-set as advised, has anyone any other ideas please?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @goldie0.24x
I have esclated this thread to Sony Support as there is really nothing else I can advise you im afraid. It seems the factory reset was merely temporary which is most unfortunate. Please ensure that you have upto date contact details in your my sony profile.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Quinnicus, many thanks for your help.
