- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I did a factory reset of my TV today. Now Sony select will not load, which means I am missing BBC iPlayer and Amazon Prime.
I tried manually starting but it comes up with the above error. Was all working fine until reset, tried multiple factory reset and still same error.
What is causing the problem, I have the firmware that came out last week
Sony XE90
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My Sony Select has started again today and my apps have returned. Can't explain what has happened but I'm releived to get it back. Would be nice if Sony fessed up though and told us what had happened instead of the deafening silence..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I know sounds daft but reassureing you are having the same problem as me at least not a tv problem, and is sony side
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@imcgarry wrote:I know sounds daft but reassureing you are having the same problem as me at least not a tv problem, and is sony side
That’s actually encouraging. So your Sony shelf does not load either and thus no BBC iPlayer? Assume you tried a factory reset too?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes i did a factory reset tonight, had previously been ok, but post reset nothing and no sony select hence no iplayer too. If you enable or go through youview it is there, but i dont like that method at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same problem here with my 65XE9005. Latest firmware too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the latest firmware but have not done a factory reset, it appears the latest firmware with a factory reset results in this error. Good old Sony.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Me too. I had factory resetted to resolve another problem I was having. Fortunately first problem gone, but now this issue.
KD49XF9005
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@bluehorseshoe85 wrote:Me too. I had factory resetted to resolve another problem I was having. Fortunately first problem gone, but now this issue.
KD49XF9005
What was the other problem out of interest?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
the whole system was running slowly and the sound was clipping every few seconds!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
