I’ve found the solution - I’ve disabled the YouView option and am now using the default EPG guide. With this guide I can now set reminders and also edit the programme list! The culprit was YouView.
Hi Testcard,
Give us some more information to see if we can solve your issue together. Which programme channel list are you referring to. Your TV comes with multiple tuners built-in, do you refer to the terrestrial, cable or satellite programme list?
Cheers,
Dutchice
Hi
Thanks for the quick reply. It’s the digital channel list from the aerial source:
Channel setup > Digital setup > Digital tuning > Programme list edit is greyed out.
Thanks for your clear answer. Would you be able to confirm the following for us:
Get back to us and we will take it from there.
Cheers,
Dutchice
Hi again
No USB devices connected
No CAM modules installed
No viewing reminders (I can’t see how to set viewing reminders in the YouView Guide, there doesn’t seem to be an option for this!)
Connected sources are Sony Blu-ray player and Sky Q satellite box.
Great! You caught me in the middle of typing just exactly that. Glad to hear you found the solution.
Don't hesitate to drop us a line if you need any more help in the future. We are here to help.
Enjoy your new TV!
Cheers,
Dutchice
Thanks again for your replies - I should probably have spent a little longer exploring the menus before posting!
Please also note that if you want to use the YouView UI again, then on going back into YouView, Skip the option of retuning (YouView try to give the impression that a retune is mandatory, but it isn’t) and your programme list editing changes will be preserved, even in YouView.
That’s good to know - thanks for the tip.
