- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have just got the 48A90K tv and I cannot find a power switch physically on the tv as opposed to the remote . I contacted Sony but they were no help, just referring me to the manual, which I had already done .The manual page 4 just showed a line drawing dotted for the supposed position which I assume was at the rear of the tv . At the rear ,which is completely covered in that position is a square with the Bravia logo but no access to any power switch . Am I missing something obvious?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've got the XR-42A90K the little brother of yours.
Go to the left hand side of the TV to the panel where you can plug in an HDMI cable and USB connector,
Centre-Speaker Synch socket and the CCA card module.
At the very top of that panel is a little square button with the power symbol, when I say it is little
it is very little, a torch and a magnifying glass may be required.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes I too spent a day looking for this power button as the (non) information leaflet that comes with it does make you look at the back of the TV.
Bookmark the link below, this is the Sony Support site for your TV, here you can get access to the User manual, downloads and Q&A's.
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/xr-48a90k
There was an update released at the end of August this year to V6.7283, your TV may have been manufactured prior to this release and therefore needs updating.
To find out which version of the software your TV is running click on the Settings button on the remote control.
Scroll left on the onscreen menu to Settings.
Scroll to the bottom of the list and click on Help & Feedback, click right and select Help.
After the page loads, about 5 seconds, you will see at the bottom left of the screen the
model number and software version.
Always best to ask the customer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPad
