I am experiencing digital channel pixelation on several channels on above tv.
I have been running two TVs from one digital aerial without any problems as the aerial transmitter is close to my address. When the pixelation occurs, I have checked the Panasonic TV in my other room and the pictures are all perfect so this eliminates any aerial problem.
Can anyone make any suggestion please.
Many thanks for your help. Problem now solved by doing a complete factory reset.
Hi @Trevene
What do the signal diagnostics show when pixelisation appears?
HELP -> Status & Diagnostics-> Signal diagnostics.
I assume that you have checked all the cable and plugs for shorts or dodgy connections.
The picture quality is 10 when pixelating occurs. I have checked all cable connections. Strangely enough, when I checked the pixelating channels this morning, there were no pixelating whatsoever and perfect pictures. The pixelating appears from early afternoon onwards.
