Hello.I installed my brand new 55a 80j amd im extremely happy so far.Its much better than my old A8f.I have only one problem that annoys me.Anytime i change channels on live tv the process is slow and a loading circle appears on screen like its loading some app.Any solution?I did all "hacks" to make android tv more smooth but nothing changed about this.
@ParisShamrock, try to clear the TV's cached data by pressing Settings > System > Storage > Internal shared storage > Cached data (There might be a slight difference in your TV path), and double check if it becomes smoother or not. Also which software version is installed?
