Hi ! My question is:
Why don't you make OLED tv screens between 32 - 38 inches (81 - 105 cm) ? There are only very big tv monitors of OLED which are not suitable for little rooms! Screens between 32 - 38 inches are of lower quality image (HD or full HD LED) which produce blur in motion, and less colors. If phones can have OLED screens why not little TV screens?
Best,
A.
[Edited for privacy]
Are you aware that Sony is not manufacturing OLED panel (or any consumer panel at all)? For OLED tv panels you should have a look (as of now, maybe changing in the near future) at what LG display is producing (as of now 48",55",65",77", 83" for 4k and 88" 8K)
BTW, phone oled panel use different technology (being RGB rather than WRGB) and are not suitable for larger sizes, as of now
Hi vasarhely, I believe that's based on Sony's market distribution, why don't you contact Sony directly for such a constructive feedback.
Hi
Sony will come with a 43" OLED later on and i probably will get it for my self. Depends if it got 2 tuners or not?
Best Regards
