had this for four weeks, suddenly started switching itself on each night between 2-3am. It is not the sky box as we have switched that off but tv still comes on. Not a good start for an expensive tv and very worrying apart from waking us up. Presume something wrong with the software perhaps. Anyone any ideas?
Hi Peter. Sorry, thought I had replied. Never did find the remote settings and TV was taken back as faulty. Changed it for a 55” Sony and so far no problems. Thanks for your help.
Hi Lowestoftlass,
Can you please check if "remote start" is enabled in the settings?
If so - please turn off.
Hi Lowestoftlass,
It should be located in the network settings:
https://helpguide.sony.net/tv/haep1/v1/en/06-03_01.html
