Went to setup a new KD-43X8309C last night.
After the initial set of steps it asked me if I wanted to download the latest software updates, which I did. It did the big download first and got that installed.
After about an hour the tv changed from the white flashing indicator to 6 red flashes.
At one stage I hit power on the remote and the screen came on to say it was updating something like app 20 of 129.
Waited another hour. Tried a couple of power offs. Still nothing.
After power up the white indicator starts flashing and then goes to the 6 red flashes.
Left it for the night and it was still the same this morning.
Any ideas of what the problem is or how to do a factory reset without the screen coming on. TV is not responding to the remote control.
TV is going back to Currys tomorrow if problem is not resolved.
Thanks
Donal
@dmcweeney wrote:TV is going back to Currys tomorrow if problem is not resolved.
Read - or rather sample - the long thread on these sets... They are a nightmare,with fundamental design flaws.
Returning it may well be your best option; especially at this stage.
Hi there
The 6x flashing red light (or blinks) generally indicates a hardware failure. Advise you to contact the retailer and get them to exchange the tv.
