I have a fibre line with low latency and jitter and content played perfectly up until a few days ago. (watched the entire series of dare devil in 4k)
Netflix support essentially made me power everything down, discharge and restart , signout of the a/c etc.
HD content plays without problem and 4k content on youtube has no issues playing.
If I kick off a 4k episode now, it plays for a few seconds , buffers and then only plays audio.
I notice that the recommendations are taking longer to load than usual at the moment as well.
Anybody else experiencing similar behaviour?
Hi there
When you are having problems, goto www.speedtest.net and see what your speed is? it is entirely possible this is a line or ISP related problem.
