Hi All;
Is Netflix available for the KD55X8509C TV pls?
I cannot believe that Sony has released a TV which includes the Netflix button on their remote control but no support for Netflix?
Many thanks
Lucio
Well I don't think your TV will sudenly teleport into another dimension, but the official line from
Sony is that they do not advise and to reassure members that they are investigating.
Has anyone gotten anything more than sterio PCM passed through the TV? I've got my PS3 connected up via HDMI3 and the sound is outputted via ARC on HDMI4 but I only get sterio out - I've currently got it set on Auto 1 which should pass any compressed audio straight through
I'm still only getting stereo through TV speakers nothing through Sony home cinema when using Netflix although sky works fine through home cinema
Just tried to use Netflix and it has stopped working and I get a message saying it is not compatible with this device
Working again this morning, issue at Netflix end according to support pages
Hi All, had an email from support this afternoon about the Netflix issue, apparently new firmware is due on the 15th June to fix the problem. Email snippet below:
<Email Snippet>
Thank you for your recent e-mail.
In regards to your query, the higher technical team advised that a new software update will be released in 10 days that will rectify the Netflix issue.
Thank you for your enquiry.
Nick
