Hi All;
Is Netflix available for the KD55X8509C TV pls?
I cannot believe that Sony has released a TV which includes the Netflix button on their remote control but no support for Netflix?
Many thanks
Lucio
OK so the quickest way to get Netflix working is to download the APK from here https://www.apkmirror.com/apk/netflix-inc/netflix-for-android-tv/netflix-2-1-build-425-android-apk-d... copy it to a USB stick and insert it into the TV.
Goto https://play.google.com/store/apps/details?id=com.estrongs.android.pop and tell it to install to your TV (make sure you're logged into your google account on the TV).
You'll need to make sure you allow installs from "Unknown Sources" which is under Settings > Security & Restrictions
On ES File Explorer on your TV navigate down to your USB stick (left hand side, just keep pressing down) and then click on the APK, then on Install.
Load up netflix and sign in / up
Enjoy the 4K goodness
Yes it should work for any apk you download
Hi NickCo1979 and MikeLothian
Thank you for your help, i have downloaded the Netflix app and the file explorer, I'll install it later tonight and hopefully have the full 4k experience of netflix.
thanks
Lucio
Hi
I have downloaded apk file and es file explorer but get parse error when I click on apk file and install, any ideas around this?
TIA
It has worked for me.
THanks for the help.
Hi all ![]()
Quick update: Sony are investigating the Netflix issue but do advise against people using different versions.
Please be careful if you choose to.
