Up until Wednesday evening my Amazon Prime app worked perfectly but now when I select the app the screen is just dark. My other apps are working perfectly. Can you help.
Also I selected solution on the messages from November but I never saw an actual solution or means to cure the problem.
Please help.
Hi there,
Welcome to the community.
Can you tell us the model number of your TV so that we can look into this for you?
Thanks,
Ed
The model is an XBR-55X900F. Thank you.
Hi Don,
Have you checked if your TV has been updated to the latest firmware?
Best wishes,
Sean Mc
