KE48A9 power switch
SOLVED
profile.country.GB.title
chance1919
Explorer
KE48A9 power switch
Can anyone who has a KE 48A9 tell me where the power switch on the tv is. I know that it is supposed to be at the rear, bottom left. That is what the manual says and what Sony support tell me. I just cannot locate it. Wondered if any other owners have had the same experience? Any help would be much appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
daveyh64
Enthusiast
I have the XR-42A90K the smaller version of the 48.
The power switch is tiny and wee.
It is almost impossible to find.
As you look at the front of the TV, go to the left hand side where you can plug in 1 HDMI device and a USB device
plus the centre speaker cable and that card slot.
At the very top of that recessed panel is a little square button, with the power symbol on it, that is it.
3 REPLIES 3
daveyh64
Enthusiast
LightFoot
Specialist
Hi @chance1919
 Just guessing, is that a power button?
chance1919
Explorer
Great. Thanks very much.
