Hello all,
I have a problem with the Google Play Store. When I open the application its Home screen flickers with what is supposed to be shown, you know... apps and such, and then it goes empty - there is nothing shown. As seen here:
Anyone have the same problem? Or better yet a solution?
OMG, changed to Wi-Fi and worked again. But there are not all the apps in there.. Missing PLEX 😞
STILL EMPTY
Well, now I have in the Sony Select app a category in Hungarian (I think)...and google translate says it means "continue to apply for workers"
Google play store gives a server error although I am on wifi.
EDIT: A factory reset solved the problem. Now Google play works and it updates the core apps. I hope this will not revert once I turn off the TV
Well I needed Google store for Plex, but the app is missing in my "modified"
store. So I downloaded it manually and istalled it over explorer. The server error and the "modified" google play store appeared after the last update. 😞
Thanks for confirming - can any others confirm too?
Sorry for the misstype. The correct version of latest google play store is 6.3.16.B-xhdpi.
Yes. Everything works fine now.
