Hello all,
I have a problem with the Google Play Store. When I open the application its Home screen flickers with what is supposed to be shown, you know... apps and such, and then it goes empty - there is nothing shown. As seen here:
Anyone have the same problem? Or better yet a solution?
same isues here, for about 3 weeks now...
Hi all
This problem was escalated to Sony Support for the original poster. I have just asked Sony if this was resolved for him, and if so what is the fix. When i get a response ill post back.
PS: Can i assume you are all on the latest firmware (PKG2.645.0052EUA for UK) and have done a factory reset?
Well, Sony support contacted me and I have send them to this thread for details about the issue + I've added the essential part that Google Play is not working well.
That was 21st of December 2015 - I've so far received nothing as a response from them.
Also my TV is EU model and the firmware that is on it is definitely EU. My current firmware is the latest available from Sony - v3.155 (from here [Bulgarian Language]).
@Anonymous Do you need the Case ID assigned for that check?
@pantalej - hmm, i can only guess that the Xmas/New Year is the delay in your case. I dont need your case id as ive found the original escalation. Either way, ill chase this up for you and the others too.
I have the same problem with a kdl 50w808c. Eu tv with eu firmware v3.155. Google store îs now showing only games , nothing în my apps or sometimes server error
Please help
Hi all
This problem is currently under investigation by Sony. I have added it to the existing bugs and issues list.
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2089584#M39405
@pantalej @alexw85 @Dione7624@silverhoe1968 @casper501
Hello all
Sony are still investigating this issue, but they would like some more information:
