Hi could you tell me is there an update to be able to access itv and channel 4 on the KDL-32WD751?
Many thanks
Hi there
If the BT Box is the BT YouView box, then yes those catchup players are available:
http://bt.custhelp.com/app/answers/detail/a_id/40469/~/youview-from-bt-and-how-to-get-it
However I would confirm with BT before doing anything.
Hi there
Unfortunately ITV Player and 4OD are catchup apps that are not supported on your TV. Only Android TV with YouView enabled will have access to those two catchup streaming apps.
Thank you, would a bt vision box give me the apps?
Hi there
Brilliant thank you it is the you view box as I am with BT.
You're Welcome
