@Bugsy1550 wrote:Can the above TV display 10 bit colour and how please?
Hi @Bugsy1550
It has an 8 bit panel but can display 10 bit (8 bit + FRC).
Without looking at your manual try Home -> Settings -> External inputs -> HDMI signal format -> Enhanced format. The chances are only HDMI 2 & 3 will support it, but the description will tell you.
Hi @Bugsy1550
Brilliant thank you
