Greetings and salutations.
I am currently unable to update any downloaded apps through the Google play store app, it constantly gives me a message insufficient Storage but they're is plenty of space.
I have tried everything and the only thing that temporary works is to uninstall Google play store updates but after the app updates problem returns.
I can side load apps without issue.
Anyone else having this issue?
Google play store version is:
21.3.14-21 [8] [PR] 3251 40660
Is your TV currently up to date? Have you tried clearing the cached data for the TV and then just use the power button for a soft reset?
If you can show us a picture of the Storage screen, that would also help clarify a bit.
- J.D.
