My new TV does not recognise either of the 2 USB sticks I've tried. I've read it is supposed to recognise them, format them and then I can record TV onto them or play movies & music from them. I've tried formatting sticks to FAT32 and I think the size of sticks are a 4GB and an 8GB. Is my TV faulty or am I missing something that I need to do??
For recording officially no stick is supported only HDD. Size limit is in anycase >32 GB aka 64GB and needs to be very fast
For playing any stick should work, try using NTFS, is the best format
You cannot do both on the same device (recording is exclusive)
Before saying your tv is faulty you should at least the manual http://helpguide.sony.net/tv/eaep1/v1/en/03-01.html
USB are not officially supported, the reason why I think they are generally too slow. But as I said there is no hard control for it and being that a 32GB stick have actually less than 32GB you should go for a 64GB to try make it works.
For playing music/video/photo any stick should work. If it says ejected it means you forced to eject it, so take it off and on again. Run the app and you 'll see it in the folder view of the app.
The device will be formatted by the tv only to make it available for recording. Once it does, you are not able any longer to see it as a PC device and cannot add any other file to it. It is dedicated to that and only TV. And recording functions will be available as per manual
