x
Sony xe930 wont update
profile.country.US.title
Siberpir8
New
Hey guys, I have a xe930 (x930e) and it won't automatically update to the latest dolby update, nor will it update via USB. When I plug the USB in es file explorer asks to open it. If I explore the usb it cannot find the .Pkg
Does anyone have any ideas?
1 REPLY 1
profile.country.GB.title
LightFoot
Specialist
Hi @Siberpir8. You could try inserting the USB and then perform a soft reboot (hold down the remote power key for 20 seconds until it starts to reboot).
