Hi Sony,
Although advertised on the front page, I cannot install either Spotify or Google Movies on my brand new A1. When I click on either app, it only displays a preview (no ability to install). I also can't install either of them from the Google Apps store (which is a complete and utter P.O.S). My region is set to the UK.
What's up with this?
To help you resolve your issue please take note of the following:
Always take into account that the better you can describe the exhibiting issue, the better we are able to assist you. So post back more details if you still have the issue.
Thanks, I updated the TV as soon as I turned it on.
When I launch the APP, it only gives me a preview, it doesn't fully load, or allowe me to browse anything useful.
It's not listed in the GPS store. It's definteley not installed.
I've installed some apps from GPS, but there seems to be a restriction in content I can see. I have a Guernsey IP address, could this be the issue? I can give you the subnet if you like?
Thanks, I treid some reboots
Sorry, one other thing I forgot to add. If I try to claim the Spiderman movie, it comes back with the message "restircted access". Again, this could be the IP address space for Guernsey is restircted?
@Sony_98wrote:When I launch the APP, it only gives me a preview, it doesn't fully load, or allowe me to browse anything useful.
Does it launch the trailers? Try pressing either BACK or LEFT or STOP on the Remote Control to stop the trailers and get to the main panel of the Google Movies App.
@Sony_98wrote:It's not listed in the GPS store. It's definteley not installed.
To verify if that is the case go to: Home > Settings > Apps. Your non-stock apps will load on the top section of all other apps. Spotify should be listed there. If it's not in the list, then it is not installed. You should easily be able to Search on the GPS app to find it and install it.
@Sony_98wrote:I've installed some apps from GPS, but there seems to be a restriction in content I can see. I have a Guernsey IP address, could this be the issue? I can give you the subnet if you like
You mention restrictions related to your location IP address. Do you mean that your IP is not recognised as a UK Mainland IP address? Otherwise you must have the YouView app and all ITV, BBC , etc. apps. If you don't have those either, possibly the issue is related to your IP address.
