- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I've been looking at the KD49XG9005 which seems to have great reviews but I have a problem in that we watch from 2 settees, each would be viewing about 20 degrees off from centre, and the reviews mention poor viewing angles. I've looked at the set in Curry's and the change from centre didn't seem too bad but....it was on a high shelf so I can't be sure if it was at its best to start with. Any advice would be appreciated. (I can't increase size beyond this owing to walls, etc)
Andy
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Any VA panel review will give you the same warning. And color shifts and contrast fade with such panels at an angle.
If you want to minimize it you should go for an IPS panel (there are plenty in the lower TV range) or to solve it completely you should wait for the 48" OLED model to enter the market later this year.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for that. Didn't realise they were going to produce that size oled- I'll hang on.
